Won't start until 3rd crank. Ideas?
Fuel Pump! In a Disco the pump itself is responsible for maintaining pressure in the line between the pump and the engine. Sounds like yours has failed the same way mine did a few years ago. The pump pumped pressure just fine, but when not running it allowed all the pressure in the line to bleed back into the gas tank. I could always cycle the key switch about 3 times before cranking and it would start up, because when you turn the key to the ON position the fuel pump pumps for a few seconds. It would run fine until I killed it out, and it would start back up if I started it quickly after killing it out, but if it sat it would not start unless I cycled the key to build the pressure back up. The good news is that the part is cheap and there is an access panel under the carpet in the cargo area to get to it without having to drop the tank. You dont have to replace the entire assembly, just the Pump itself. Airtex makes a unit that works great and it's availble at Advance Auto Parts. That's where I got mine. I think it was 80 bucks.
Here is the link to the thread I started and helped me tackle this issue way back when. Still running strong! https://landroverforums.com/forum/di...options-54600/
Markster
07-13-2015 05:39 PM
