Worn key or ignition?
I've had the same symptom with the ignition switch cylinder in my truck for 3-4 years. Like Ben said, after inserting the key fully I have to pull it out and eighth of an inch or so to find the sweet spot where it will turn. I haven't minded that; it's a form of theft protection. But yesterday, for the first time, I inserted the key fully but it got stuck and I couldn't pull it out. Eventually it came out and worked fine the next couple of times I started the truck, but having the key in the ignition with it unable to turn or be removed was not fun.
I may try the fix linked in the Write-ups, How-tos and Must Read sticky, but it's not clear to me how it would correct the problem the OP and I describe.
wastedincome
10-20-2012 06:02 AM
