Wrench size?
Old Sep 29, 2006 | 09:15 PM
ArizonaDisco's Avatar
7th Gear
Default Wrench size?
I need to remove the fan and viscous coupling from in front of the water pump pully. What size is the nut on the end of the pully shaft? Looks like 1 3/8. Thanks
Old Sep 30, 2006 | 11:10 AM
Default RE: Wrench size?
Looking at the catalog from Atlantic British, the speciality wrench for a D1 up thru 95 is a 32mm and it is very thin so as to be able to slip in to reach the nut. They don't show a wrench for a newer Disco so I don't know if there is a different on or not for yours.
Mike
Old Sep 30, 2006 | 06:59 PM
7th Gear
Turns out to be a 36mm. I forgot some vital info. on my post-'96 Disco 1. With some effort and a few scars I got the viscous coupling off the water pump pully.
philwarner
Sep 1, 2014 02:57 PM
aarongregor
Dec 9, 2011 05:45 PM
2002 freebie se
Freelander
Jan 5, 2009 04:20 PM
bklahl
Jul 9, 2006 11:28 PM
FORDSTANGER
Jun 28, 2005 11:13 PM
