Wrong Gas, New Noise?
Hey Everyone:
I stopped to get gas on my 2003 LR Discovery this afternoon.
The man who pumped the gas may have put in the wrong type of gas. I asked for "Medium", and the receipt says "Unleaded Plus"
However, after I left the pump, whenever I pressed the accelerator, the engine began sounding a bit more high pitched than normal. All the gauges were fine, and the car operated perfectly; Even when idling.
However, when I turned the wheel when coming out of a stop, I noticed the noise a bit more. Again, the steering felt fine and the vehicle feels fine.
I checked the power steering tank, and both ACE and standard fluid levels are slightly above the "MIN" level.
I checked under the car for a leak, and there appears to be a VERY small puddle, which has the consistency of oil. The puddle is directly below the oil filter. I had the oil filter changed and oil changed a few days ago. Frankly, I have never checked for fluids under my Rover before, so this may just be normal condensation from running the AC a bit.
What is going on?!
What is going on?!
Since "medium" isn't a term I've ever heard used for fuel, I would have guessed plus as well. Did you intend to get 89 octane fuel? Because that's what you got.
AC condensate doesn't come from under the oil filter, and it isn't oily. You have an oil leak. It could be as simple as the filter not being on tight enough. Put your hand on it and tighten it.
I have no idea about the noise. Sounds like the PAS (power steering) pump. After driving, how does the fluid look in the reservoir? Is it foamy?
Thanks for the response.
I haven't look at the fluid after driving. (I was afraid to open the cap, as the manual states only do this when the engine is cool - Maybe I'm just too much of a rookie hehe)
I'm having new tires put on tomorrow, so I'll mention it to the mechanic when he lifts her up.
I'll keep you posted, though.
Thanks again!
Thanks again!
Hey Everyone:
What is going on?!
What is going on?!
If it has the consistancy of oil, it is probably oil...who changes your oil?...whoever did might have over tightened the filter and crushed the gasket...or maybe didn't replace (or put back) the washer from the bolt that drains the oil pan.
That's your coolant reservoir. The power steering reservoir is on the other side of the engine compartment.
Twistid
12-19-2012 07:51 PM
