WTF. No wonder I was leaking oil...
So I had a V/C leak and decided to change out the gaskets. I had a mechanic replace them about 2 years ago, and had to take it back within a year because they started leaking again. Needless to say, they were leaking again so I decided to replace them myself. Got it done, and they aren't leaking anymore, but check out the gasket from the leaky side. What could cause this to happen?
Gasket gnomes have been known to slash gaskets, but never caught in action. That's one possibiliby. More likely, they were mis-installed last time causing it to bend-over and break. Or, they may have been defective from the mfgr. Anyway, a good mechanic would have gotten them on straight or should have caught that. Another good reason just to do it yourself...
Due to the metal inserts in the hole where the bolts go, it's hard to over torque the gasket. From your pic it's hard to tell if the metal inserts are there. Maybe they fell out and the prior mechanic didn't notice it was gone. Then he proceeded to over torque the gasket causing it to tear prematurely.
skezixx
Off Topic
10-23-2011 08:55 PM
Frank4
06-03-2010 09:12 PM
Disco Mike
10-16-2007 05:53 PM
Lnghrn Disco
06-14-2007 12:48 PM
