wtk info on 1998 discovery?
Old Mar 21, 2009 | 10:42 PM
TOM R's Avatar
Default wtk info on 1998 discovery?
hi i have been looking at buying a discovery and some discoverys seem to be rotted out in the same spot under the door strikers on both rear doors is this a common problem? are there any other common problems I should look for when checking out one of these trucks? thanks
Old Mar 22, 2009 | 08:57 AM
SDinDS's Avatar
I have the same rust as you mentioned and from what I've read, it's a common problem... especially if you live in the rust belt. The only other problems I know of are door handles, door latches and the CDL shifter being seized up from lack of use. Also there are a few electrical issues you might find, like sunroof not working or rotary coupler is bad. The engine and tranny in these are terrific. Just minor problems that creep up on occassion. How much are these Disco's you're looking at?
Eric
Old Mar 22, 2009 | 10:06 AM
Common problems on DI's are the ABS light being on, the cruise control not working, sunroofs not working, rear windows not working, power door locks not working, cargo door wont open from the outside, CDL level being seized.
All of these are common and easy DIY fixes so dont let them worry you, just use them to your advantage to haggle a lower price.
Old Mar 23, 2009 | 05:58 PM
TOM R's Avatar
I am looking at a 1998 blue with tan leather int, has rear jumpseats, rear air, rear defrost on all 3 big back windows, all power windows work, has the brush bumper in front and the ladder on the back and has the heavy duty military type front axle, it is $2200 with salvage on the title, this includes getting the title straight with dmv so I can register it, it is a recovered theft, the front seats and seatbelts were gone, it is at my friends shop and I saw it when it came in from the auction thats all that was missing, it runs, no smoke, no noises and drives and stops i will be using a dealer tag when i get time to drive it and make sure everything works (like the trans), 4x4 shifter is stuck in 4x2 and there are the 2 rust holes 1 under each rear door striker, he has a rolled one for me to scavange any parts I might need, we already replaced the seats, i didn't notice what the miles were on it, has working keyless entry, i am in n.j. usa
Old Mar 23, 2009 | 07:02 PM
The two "defrosters" on the side windows are the FM and AM radio antenna.
These trucks are FULL TIME FOUR WHEEL DRIVE THERE IS NO TWO WHEEL DRIVE OPTION!!
Old Mar 23, 2009 | 09:02 PM
oljohnboy's Avatar
Tom,
I think that after you invest money to bring this vehicle up to speed, you could get a disco with a much better history. Things that I would check that may be out of the ordinary
axle fluid- mine had water mixed with oil in rear axle due to leaking breather valve on top of axle.
do you need to tow? do you have the american trailer light plug?
do you have the crossmembers for the roof rack?
how about the lug wrench--it is a large size that I cant seem to find at an auto store
radio require code?
tie rod ends- the rubber dry rots and if one fails, you could loose control of the vehicle
rotors and brakes-- they are very easy to change the pads and inexpensive, but I have never seen rotors that are damaged so easily.
exhaust system rust
I know that these are things that I have had to address on a 98 disco 1 that was actually in really good condition.
John
Old Mar 24, 2009 | 08:23 AM
TOM R's Avatar
ok then the diff shifter is stuck
Old Mar 24, 2009 | 08:30 AM
TOM R's Avatar
[quote=oljohnboy;108625]Tom,
got a diesel truck for towing
i think these are there
lug wrench and jack and spare tire all there
radio require code?
yes it needs the code guess they will goto the dealer like the usualy do unless there is a list here
still need to shakedown the front
I used to be a buick dealer tech so I try to do as much myself as possible
exhaust system rust
I hear a leak so it will need exhaust work
how are these on gas? 15mpg?,10mpg?, 2mpg?
Old Mar 24, 2009 | 04:02 PM
You MUST use premium gas, and when well tuned and driven right you can expect 15mpg as a daily driver, 18-20 expressway.
Old Mar 24, 2009 | 07:10 PM
okdiscoguy's Avatar
uh, just my 2 cents, but the rotors are not that easy to change. You have to pull the axles on the rear, and the drive members on the front. The rotors are bolted to the backs of the hubs. You have to service the wheel bearings while you are there.
On a D2, you pull the caliper and pop the rotor off...
Just didn't want you to think it was going to be a quick job. Not necessarily hard, but not quick by any means, and a lot more complicated than most.
