XYZ Switch Connector Stuck
Old Aug 11, 2018 | 05:52 PM
Rover_Naut's Avatar
4th Gear
Default XYZ Switch Connector Stuck
Soo, the xyz (neutral safety switch) on my '04 Discovery 2 just doesn't seem to want to unplug. I even used a flat head to try and help, but I didn't go crazy with it because I don't want to screw it up. I just don't know what I'm doing wrong. I depressed the tab on the one side, but it just doesn't let go. Anyone experience this before or have any advice? It's insanely frustrating.
Old Aug 11, 2018 | 07:35 PM
mln01's Avatar
I don't know how much this will help, but did you remove it from the "tab" on which it is mounted. If I recall correctly, it makes it easier to disconnect that way. And this may be silly advice, but I always lie with my feet toward the passenger side when accessing the XYZ. I find that easier.
Old Aug 11, 2018 | 08:37 PM
Rover_Naut's Avatar
4th Gear
I appreciate the suggestion. Yeah I also found feet towards passenger to be easier. As far as the bracket mount it's on I ended up unscrewing it from the transmission in an attempt to free the xyz switch. The little clip looking bit on the side is rusty and wouldn't come free. :-/
Old Sep 20, 2018 | 08:54 PM
Rover_Naut's Avatar
4th Gear
I realize I forgot to update this thread, but the metal clip that the connector is holding on to is actually going through and holding the connector together. You have to remove the connector from the clip in order to pull the connector apart due to a secure hub that sticks out when the connector is together. I'd attach a picture but it's not liking me at the moment.
Rhino007
Mar 13, 2019 01:23 PM
Toran
Sep 20, 2018 10:24 AM
Disco2 MTL
Dec 17, 2014 10:44 AM
ktm_525
Sep 4, 2012 10:43 AM
chaz
Feb 24, 2012 10:13 AM
