Is the y pipe the same for all DII's?....
Old Sep 4, 2012 | 09:34 AM
agthird's Avatar
Default Is the y pipe the same for all DII's?....
I have an 03 looks like they are the same for all models I need to replace my cats and looking for a good deal on a replacement any ideas where to pick one up?
Old Sep 4, 2012 | 09:59 AM
jafir's Avatar
They are the same for all North American D2.
Old Sep 4, 2012 | 02:16 PM
Or you can just cut out the old cats and install new ones along with new 02 sensors.
It would be worth your while to determine why both cats failed so it doesn't happen again.
Why or how do you know they are bad, what fault code numbers do you have?
Old Sep 4, 2012 | 03:38 PM
DiscoKline's Avatar
I purchased a complete Y pipe assy from www.discountcatalyticconverters.com and went with the Davico system. Looks like they are around $360 right now. Mine had already been replaced by the prior owner, and I figured that they were around $100 each for both the cats, plus labor to weld them in. It wouldn't save much going that route, and this way I get a new assy ready to bolt in. Mine fit perfect, and so far has worked well.
A word of caution when you remove the pipes from the manifold is to use an impact. I broke 4 of the 6 studs, and had to put in two heli coils because I could not get the reamainder of the studs out.
Old Sep 4, 2012 | 03:49 PM
agthird's Avatar
Mike the drivers side is throwing a code for bad cat the other side is an after market that was a hatchet install due to the PO front drive shaft going bad...so I want to go with the whole unit instead of a piece meal...
Old Sep 4, 2012 | 03:55 PM
agthird's Avatar
Discokline can you explain the use of an impact?
Old Sep 4, 2012 | 05:54 PM
coors's Avatar
Search for my thread on here about the Davco unit and where to purchase.
FYI zthe davco unit uses much smaller cats. Your exhaust will sound more hollow than you're used too.
Like I said search for my thread for my full review.
Old Sep 4, 2012 | 05:55 PM
coors's Avatar
Yes, 99-04 uses the same Y-pipe design.
Old Sep 4, 2012 | 06:38 PM
hilltoppersx's Avatar
only different setups are the diesels... ask me how i know
Old Sep 4, 2012 | 09:37 PM
How do you know?
