Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Adaptive speed limiter option
Old Nov 2, 2019 | 05:13 PM
asteng88's Avatar
Default Adaptive speed limiter option
Hi everyone,
First post on here so excited to be a member and hopefully contribute in the future.
I have an '18 disco sport and I see an option for the adaptive speed limiter but I cannot check the option to switch it on (it is greyed out).
I have the speed sign recognition option so I am wondering if this is a software option or I need additional hardware to switch this on.
Can anyone point me in the right direction?
Many thanks
Andrew.
Old Apr 9, 2020 | 04:23 PM
Stroh's Avatar
Mine is greyed out also and I was wondering the same thing. It works from the steering wheel control. Perhaps you aren't allowed to change it from the menu, but only from the steering wheel?
Old Apr 13, 2020 | 02:10 PM
Stroh's Avatar
I played with the Adaptive Speed Limiter quite a bit the last couple of days and really like it. I did discover that the Adaptive Speed Limiter menu option in the Driver Aid menu is greyed out if the Speed Limiter/Adaptive Speed Limiter is not active. If you press the LIM button the Speed Limiter icon will show up on your dash in a grey color. You can press and hold Cancel for a couple of seconds and it will switch to Adaptive Speed Limiter and the icon will change. You can also switch using the menu you found. If you press the LIM button and the Speed Limit icon shows up you can go to the menu and select the check box to change it to Adaptive Speed Limiter, you can uncheck it to switch it back to the basic Speed Limiter.
Old Feb 15, 2021 | 08:05 AM
garymaydon's Avatar
5th Gear
can anyone advise whether theASL can be permanently on- so that you do it need to activate every time you switch the ignition off
Old Feb 16, 2021 | 03:40 PM
Stroh's Avatar
I asked about that at the dealer and was advised it is not possible to default to on.
Red Flash
Discovery Sport
Feb 17, 2021 05:17 AM
Bago
Feb 28, 2018 03:39 PM
Volkov
Dec 31, 2015 02:32 AM
vorticistssuite
Nov 23, 2013 03:20 PM
nuclearw
Sep 27, 2013 09:08 AM
