Driver rear window goes down when engine started
This morning went out to the car and when I started the engine the rear driver window went down and won’t go up with front or back controls…but when I stop the engine and hold the lock button the window goes up…. So strange any suggestions or easy fixes would be appreciated! Also when driving window won’t go up,
Hi Boyle,
I have a RR Velar 2019 and randomly the exact same thing is happening to the rear driver side window. I have also noticed that the dimmed light on the same doors corresponding switch when ignition is on is also dark. Then I turn the car on and the switches are on full brightness it’s lit up correctly bht when car is turned on, window goes down and unable to bring it back up. When car off I am able to bring them back up.
did you ever find a solution to this?
another electrical RR glitch?
Thanks in advance,
Nick
Thanks in advance,
Nick
