Discovery Sport Talk about the new 2015 Land Rover Discovery Sport
Low Battery, restart the engine? Turbo Charger Help!
Old Dec 4, 2022 | 06:42 AM
Marshalogan1976's Avatar
Default Low Battery, restart the engine? Turbo Charger Help!
My Turbo Charger recently acting up (Have to get new one) noticed when I cut my car off it now says "Low Battery, re-start engine? I was thinking it needed a new battery, however, put a new battery in, it stills says this, curious if anyone knows whats going on? Also I want to purchase a Turbo Charger Kit, what is the cheapest/best place to get one? Thanks!!!
Old Dec 4, 2022 | 08:59 AM
Canuk's Avatar
What is the turbo charger doing that you think it needs a new one??? What style of battery did you put into the car???
Also what year, model and engine do you have.
Old Dec 4, 2022 | 12:04 PM
Default Low battery n turbo charger
it is a 2015 Land Rover Discovery 4 cy …… I took it to a shop to be fixed n they said it was the turbo charger ….. the codes also confirm that. The car each time I cut off the car would immediately say Battery low restart engine. So I got a new battery n that did not fix that problem. Curious if those two were connected?
Old Dec 4, 2022 | 10:05 PM
Canuk's Avatar
Did the shop that installed the battery reset the battery monitoring system ? Many owners have not had to reset it but others have needed a reset. I image that the shop checked out the charging prior to installing the battery so the alternator should be OK...
But place the car on charge overnight using a smart charger and it most likely will help. Land Rover and most Disco owners use a CTEK charger.
Low voltage can cause many problems or cause the car to show errors that are not there.
bennyl
Jan 25, 2022 03:37 PM
mmbirtcher
LR4
Oct 13, 2021 04:27 PM
Angela Clow
Range Rover Evoque
Mar 22, 2021 08:42 AM
longtrip68
Feb 5, 2019 10:26 AM
bobco
Dec 17, 2010 08:27 PM
