Engine & Internal Chat about beefing up your engine's insides here.
Details on how a Rover engine operates
Old Dec 19, 2015 | 01:34 PM
Ole Miss Texan's Avatar
Default Details on how a Rover engine operates
Had trouble finding what I'm looking for and bet the forum can help (as usual). Is there a detailed breakdown of exactly how the engine operates? Ideally I'd like to make notes for how my '04 D2 4.6L V8 operates from start to finish.
For example: from turning the key a step by step guide of what each part does and where that's located in the vehicle. How the oil, coolant, air, radiator, pistons, transmission, driveline, and flux capacitor all work together in tandem to do what we need them to do.
I have zero experience in working on cars and am excited to learn. Although this is my first rover I know it's not the last!
Old Dec 19, 2015 | 04:02 PM
Charlie_V's Avatar
That's a tall order! I've never seen one but the RAVE manual comes close, but at over a thousand pages, it should.
Old Dec 19, 2015 | 04:31 PM
Haha my bad! Not looking to be an expert. Just a place to learn the basics - I'll check out rave manual
Maybe someone knows of a cliffs notes version online
Old Dec 19, 2015 | 06:58 PM
number9's Avatar
Default All But Flux Capacitor
Rave has all/most of the info in the Workshop Manuals & Electrical Circuit Diagrams but requires some jumping around to put into story form. Helps to have had experience with other technical manuals and once a PDF file is open the search function is useful.
D2 Workshop Manual has a description/operation at the beginning of most sections and probably where you'd like to begin. Enjoy.
Old Dec 21, 2015 | 09:49 AM
drowssap's Avatar
u-tube is filled with videos that will give you plenty of the basics you need to know.
maybe find yourself a couple interesting ones watch and then read the corresponding chapter RAVE after to find the LR specific differences.
Old May 17, 2016 | 04:45 AM
loanrangie's Avatar
Get a book on old Buick V8's, the Rover is not much different apart from the electrics.
Old May 17, 2016 | 12:37 PM
binvanna's Avatar
The RAVE manual is a good place for things specific to the Discovery, but it's more suited to troubleshooting and maintenance or repair. It sounds like you'd benefit more from a basic explanation of internal combustion engines. If you don't understand how a lawn mower operates, there's not much point in focusing on Buick or Rover specifics.
Start with the basics of the 4-stroke "Otto" cycle. Check out "volumetric efficiency." Learn about multiple cylinder configurations (twins, fours, sixes, and V8's). Look at the different valve arrangements (side-valve, overhead valve, overhead cam, etc.). Study air/fuel mixtures, stoichiometric ratio, carburettor vs. fuel injection. Study ignition, learn how spark plugs and "points" work, a distributor, and then electronic ignition. Then learn about wet sump lubrication, pressurized cooling with coolant to air heat exchangers (radiator), and then gearboxes, automatic transmissions, transfercases, driveshafts, ring and pinion gears, differentials, axles....
Old May 17, 2016 | 11:13 PM
Joemamma1954's Avatar
As per binvanna's recommendation:
Animated Engines - Four stroke
Old May 5, 2020 | 07:28 AM
TimInNova's Avatar
Discovery Series 2 Engines - Dealer Training Video about Td5 and V8
bcbp
Oct 20, 2012 12:27 PM
Quiksilver1850
Apr 18, 2011 06:11 PM
ek5usmc
Oct 12, 2008 03:03 AM
bcolins
Oct 11, 2008 08:23 PM
BURover
Sep 6, 2007 12:43 PM
