Engine & Internal Chat about beefing up your engine's insides here.
Ditching the Viscous Cooling Fan
Old Jun 9, 2006 | 12:45 PM
btp226's Avatar
Default Ditching the Viscous Cooling Fan
I keep reading about the alleged performance & MPG increase by removing the stock cooling fan and replacing it with a thermostatically controlled electric unit (Kenlow, etc). Has anyone here actually done this and what (if any) increases did you notice?
Thanks,
Brian
1995 Disco (petrol, AT)
Old Jun 30, 2006 | 12:37 PM
btp226's Avatar
Default RE: Ditching the Viscous Cooling Fan
I guess no one here has ever done it then? I may be the first to "experiment".
Old Aug 14, 2006 | 08:39 PM
Landzu's Avatar
Let us know how its working.
Old Mar 22, 2007 | 10:29 PM
silverseven's Avatar
I actually did this 2 days ago. I replaced the viscous fan with two 14 inch electrics. I used a Hayden electronic fan controller I bought at Checkers. This little unit is awesome, as it is pre-wired for 2 fans, has it's own relay, it's own temp probe, and the engage temp setting is adjustable. The truck runs much quieter now, and the fans don't run all the time like the stock one did. As far as performance and mpg gains, the truck feels a tad faster, but we shall see over time about the mpg.
Old Mar 22, 2007 | 11:01 PM
werldcup's Avatar
What brand fans did you use?
Old Mar 24, 2007 | 04:13 PM
They are Hayden Rapid-Cool 14 inch fans. I had to trim the edges slightly to get them both to fit against the radiator, but you can't even see that when they're installed. I bought them at Checker (Shucks, Kragen) for around $60 each. I have the relay temp adjusted to just past the thermostat's cooling point, so the fans only turn on if the thermostat can't make it by itself. The "ignition" wire for the relay is connected to the hot wire on the brake master's sensor cap, so the "brake" light comes on in the dash when the fans are running. Kinda nice so I can see when they are on.
Old Mar 28, 2007 | 12:07 AM
greg409's Avatar
Nice touch -
I used a two speed Lincoln 16" 4500 cfm w/ two relays (30a ea) fused thru bat.
I pull it in (hi/lo) with dp/dt (center off)switch mounted under dash
I've only used low speed normally even if a/c is on
My viscous coupling was going so it runs smoother & seems to jump off idle a little quicker
'97 D1
Old Mar 29, 2007 | 11:33 PM
deadclock's Avatar
Hayden is a good brand for fan and other parts. I had this problem with my jeep fan clutch when I noticed a leak on it. Not sure why it became unsealed. So I replaced it. [8D]
Old Oct 21, 2007 | 07:26 PM
N.Franklin's Avatar
How much room did it save you in the engine bay?
Old Oct 21, 2007 | 08:37 PM
Willie 00D2's Avatar
Have you noticed any differance in fuel consumstion or power?
Willie
jafir
Feb 10, 2017 11:08 AM
Jawbox
Jun 4, 2012 04:52 PM
Camdisco24
May 30, 2008 03:12 PM
apcollin
Mar 27, 2008 09:22 PM
okdiscoguy
Sep 19, 2007 12:15 PM
