4.6 P38 into Disco 2- oil cooler delete??
'04 Disco 2 had slipped sleeve along with other leaks..... so I'm in process of swapping to a engine from a P38. Old engine is out, prepping for new install, I realized the replacement engine has the oil coolant lines. I think I read somewhere that when the '03 facelift was done, the oil cooler was deleted and no longer fits.... not sure about that part, but I don't have a cooler on the disco now. Does anyone know if I can simply plug the holes at the pump and move forward? I could also change the timing cover to the one off the old engine? Anyone dealt with this?
Thanks!
Thanks!
irishrover
03-25-2007 12:34 PM
