Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
D2 swap Dodge 318 with NP435
Old Dec 27, 2025 | 10:27 PM
Disco Dad's Avatar
Default D2 swap Dodge 318 with NP435
I have a line on a 1976 Dodge W100 truck with a 318 and NP435 4 speed. I’m thinking about finding another dead D2 (I have 2 running currently) and swapping those in while leaving the LT230. AM I CRAZY? I don’t care about fuel injection or the electronics, Perfectly happy with manual gauges if need be. The idea of an old power plant and granny low kinda sounds fun. I’d like any input y’all have.
Old Dec 28, 2025 | 02:11 PM
PickleRick's Avatar
That's a short trans. You can spend a few hundred making the lt230 divorced. Attach the 4 speed with a stub shaft. No idea on the length there but the stub shaft needs to be 9-12 inches long.
Old Dec 28, 2025 | 09:53 PM
Disco Dad's Avatar
I didn’t think about doing a divorced transfer case. I should’ve considering the Dodge has the same setup. Thanks!
Old Mar 16, 2026 | 04:47 PM
Minty.Disco's Avatar
4wd High
I have a 5.9 (360) magnum and NV3550 out of a wrangler swapped into my disco. Worth it. Biggest challenge will be starter clearance and finding manifolds that aren’t a problem. I have 80s finned exhaust manifolds on mine.
be forewarned it’s a crapload of work, and youll need an adapter to the transfer case if you want to retain the LT230.
LADEROUTE
Jun 2, 2018 04:08 PM
22Dirty
Aug 25, 2017 12:45 PM
OffroadFrance
Dec 7, 2016 07:24 PM
Fizzbiz
Aug 8, 2016 01:25 PM
nahtanoj
Jul 13, 2012 02:15 AM
