4.6 engine swap for 4.0 in a D2
Old Jul 6, 2016 | 12:57 PM
Fizzbiz's Avatar
Default 4.6 engine swap for 4.0 in a D2
Anyone installed a 4.0 in a D2 to try to get better reliability. If so what are the pros and cons.
Old Jul 6, 2016 | 07:58 PM
DiscoCam's Avatar
It's pretty much a direct swap. But I believe you need to reprogram the ECU or use the one from the 4.0 truck. You also lose some power because of the smaller displacement.
Old Jul 15, 2016 | 08:37 AM
toad2's Avatar
I swapped out mine. No problems at all. Didn't reprogram anything.
Old Jul 16, 2016 | 02:15 AM
JimmyChooToo's Avatar
Did you miss the horsepower ?? Thx.
Old Aug 6, 2016 | 04:38 PM
toad2's Avatar
What horsepower, hahaha?
Seriously, no. My 4.6 was only running on about 5 or 6 cyls when i swapped it.
Old Aug 7, 2016 | 10:52 AM
Charlie_V's Avatar
I've swapped 4.0 to 4.6 and back, more than once. No reprogramming. No issues as long as they are both SAI, or not, and it you go from an SAI setup to a non SAI youll need to swap the heads. If, like me, you didnt start with SAI you just have to plug the holes or swap the heads. Everything bolts right up.
The difference between my old 4.0 and a freshly rebuilt 4.6 is pretty stark, power wise.
Old Aug 8, 2016 | 07:06 AM
Fizzbiz's Avatar
Thanks for the info. I think I'll stay with a 4.6 due to the power loss. Now just need to find a good engine.
Old Aug 8, 2016 | 01:25 PM
Best4x4's Avatar
Slap an oil cooler on the 4.6L! Still can't believe LR got cheap and left that off 03/04 D2's!
bennyb43
Dec 11, 2013 08:17 AM
double R
Engine & Internal
Nov 9, 2007 12:50 AM
RJADM2000
Mar 3, 2007 02:06 PM
xb70valkarye
Sep 22, 2006 10:45 AM
Justin
Feb 11, 2005 01:55 AM
