Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old May 2, 2022 | 01:21 PM
  #1151
Karmakannon's Avatar
Originally Posted by Boostle
Problem is im using a sheet metal style intake manifold. No provisions for it. Is there any downside to deleting it all the way back to the fuel tank? Will there be a strong fuel odor? Will my truck catch fire? Lol
interesting. Does it not have vacuum ports? I thought the evap just connected to manifold vacuum, but I don't recall. From what I've read about guys that have taken the evap out it can cause gas fumes if the evap line is open and hard/ or slow to fill tank with it capped, or the need to use a vented cap. Sounds like you might want it even if you don't need it for emissions.
After my limited research, I was willing to put retaining the evap pretty high on my priority list.
Old May 2, 2022 | 06:34 PM
  #1152
CaptainAaron's Avatar
In my opinion it should be done. Easy to hook up - you just follow the ACE purge valve manual and get the one adapter piece from Novak. I think you end up getting better gas mileage because it burns the fumes from there when you have your foot off the gas.
Old May 10, 2022 | 04:46 PM
  #1153
Boostle's Avatar
Engines in! Wasn't too bad at all. My motor sits very even compared to everyone else. I loosed all trans and engine mounts before dropping it in
Old May 19, 2022 | 06:46 PM
  #1154
Boostle's Avatar
Almost at the finish line. Relocating the battery to the driver side.
Old May 27, 2022 | 08:41 PM
  #1155
rynoman1's Avatar
fire!!!!
Old May 28, 2022 | 08:11 AM
  #1156
Boostle's Avatar
Battery relocated to the driver side. I'm using zero gauge wire to run to a junction box on the passenger side right above the intake.
I just need to install an electric fan, fab up the exhaust and run the GM wiring and it's ready to fire up
Old May 29, 2022 | 07:43 AM
  #1157
homerj's Avatar
Very clean. I've been looking at mine wand thinking something similar would work nicely. I'll be watching your build very closely. Which electric fan setup are you thinking of using?
Old May 29, 2022 | 12:26 PM
  #1158
Boostle's Avatar
Thanks. I bought a derale dual fan setup that captainaaron suggested but after receiving it I realized it just won't work with my setup. I'm using a forward outlet waterpump so that theres room to run the intake to the passenger side. That interferes with the fan setup. I'm going to try a slim 16" spal curved fan setup. If the temps aren't great I'm going to add a summit racing alum shroud that I saw.
Old Jun 1, 2022 | 09:02 PM
  #1159
Boostle's Avatar
16" spal curved fan is in. I plan on having the ECU trigger it along with whenever the a/c fan turns on. I will keep a close eye on temperatures and see how it does without a shroud.
Old Jun 7, 2022 | 09:44 AM
  #1160
losinov's Avatar
You might have the cleanest engine bay i've seen thus far! Really like the look after swapping the battery and air intake.
Can you walk us through some of the extra bits that you chose to go with? seems like you have an aftermarket intake manifold? I think I see a catch can over on the passengers side as well.
