Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Jan 25, 2019 | 08:24 AM
  #231
BackInA88's Avatar
How about under the passenger seat.
No one uses a CD player anyway and you may be able to make a bracket using the CD mounting holes?
Old Jan 25, 2019 | 09:30 AM
  #232
OakBehringer's Avatar
I vote for the best compromise between cheapest and easiest. The glovebox is expendable to me.
Old Jan 25, 2019 | 11:02 AM
  #233
mollusc's Avatar
i'm not seriously looking at an engine swap right now, but losing the glovebox would be a deal-breaker for me. i'd stick with a rover v8 even with its issues.
Old Jan 25, 2019 | 03:12 PM
  #234
Wow. Curious, why is the glove box more important than mechanics reliability and longevity?
My advice to the kit builder: do what’s easiest for you to get to market ASAP. Better to get to market ASAP with a minimally viable product than it is to try to please everyone right off the bat.
Such an exciting product.
Old Jan 25, 2019 | 04:17 PM
  #235
ACEngineer's Avatar
I've thought about this, but unfortunately the trunkline of wires would be difficult and obtrusive.
So, here's the solution that seems the most viable at this point. The spot for the jack right behind the battery is a good alternative that is free and doesn't require much modification. The ECM fits well and it is out of the elements. The GM harness does not have to be modified for length and no major trunkline is required. That should solve most cases if people do not want to lose the glovebox.
One of the great things about this swap is that the LS gives you flexibility. I think long term we will see a bit of variation between builds, to reflect the individual taste of the owner. We may introduce waterproof boxes up against the firewall as an option in the future. For the next build we will put the ECM in the jack location.
Old Jan 25, 2019 | 05:42 PM
  #236
Daedrix's Avatar
Banned
I made a dual battery tray years ago so i can just fit it in one of the battery slots.
Old Jan 25, 2019 | 07:16 PM
  #237
This sounds great. And I totally agree with you on the future of the product being implemented in various ways. For me, personally, I enjoy projects and solving problems like this. I can NOT design and CNC mill an adapter between the engine and transmission. I need you for that! But something like “where to put the ecu” is a problem I’d be excited to solve.
Thank you for your commitment to this thread!
Old Jan 25, 2019 | 10:22 PM
  #238
DiscoCam's Avatar
I believe that this is the ECU location on the TD5 D2s so it should work just fine.
Old Jan 26, 2019 | 01:41 PM
  #239
ACEngineer's Avatar
Yes, it is. For people that don't want to lose the glove box, this will work great.
Old Jan 30, 2019 | 11:11 AM
  #240
losinov's Avatar
Found this LM7 swapped Land Cruiser on Reddit today. Oh how the mighty have fallen. Didn't expect to see this swap on a vehicle known for it's reliability. I guess the transmissions on these aren't as robust as the ones in the 03-04 discos.
https://www.reddit.com/r/projectcar/...go_and_now_to/
