Discovery 2 LS Conversion
#431
The following 2 users liked this post by 05TurboS2K:
ACEngineer (08-09-2019),
gilberjm (08-10-2019)
#432
The following 2 users liked this post by CollieRover:
#433
Huge congratulations is in order to you and the rest of your team, Ace.
Thank you to Gilber and Carter for posting about their experience, it was really relieving to hear how smooth their swaps went.
I'll be ordering once I know the LM4 engine I have is on the right track.
Ace - I've heard that the engine harness of the vehicles with the LM4 engines is slightly different that the ones that came on vehicles with the LM7. Would you recommend finding a harness that originally hooked up to an LM4 or just grabbing one for an LM7?
#434
#435
Thank you all for the support! I hope that this can help keep many Discoverys on the road for a long time to come.
The harnesses are different, but it shouldn't really matter. I would get a new, standalone harness, over an old, used one. Feel free to email me about options.
#436
#437
I'm also right on the boarder of Redmond/Woodinville! Very ironic. I just ordered my kit a day ago and my engine bay is now empty. If you care to jump in on this install and use mine as a learning platform you're welcome! I'm free most weekends and some evenings during the week. It'll be a month or a little more before the kits here still.
#438
Rich Spiess (08-12-2019)
#439
This seems relevant.
>>> DBW to DBC Conversion 03+ Harnesses <<< Click there and have a look.
DBW to DBC conversion info for 03+ harness
I too noticed there was no good way just looking at the already pulled ECUs to know anything more than their RED/BLUE or RED/GREEN designation, this seems to give a little more data which we can put to use in some cases.f
At the very end he talks about using a RED/BLUE ECM, which by the way is $50 bucks or less and a dime a dozen. I THINK he's saying the harness can be modified to be used as a typical RED/BLUE harness even though it's a GREEN BLUE harness, so long as you modify it. I know ACE said it may be possible to have it done. So, perhaps what he spells out is just what needs to be done. I couldn't quite tell if he was saying a 03Van DBC harness could be used with a RED/BLUE PCM or if a 03DBW harness could be used with a RED/BLUE PCM, which is what I would be needing.
For me, I've got a LM4 lined up but sadly it comes with a GREEN/BLUE ECU and matching harness which I'd have to spend $500-750 to replace new and throw away the included harness, then a cable throttle body and matching sensors. So others may find themselves in a situation somewhat like this.
"If you have a RED/BLUE connector PCM, you CAN use this pcm on a 03+ harness (GREEN/BLUE connector) with cable throttle, with a few simple modifications. The only thing that needs changed, other then what was talked about above, is some of the oxygen sensor wiring. On the 2003+ blue/green connector PCM's, the PCM supplies a GROUND for the oxygen sensor heater's, and 12v+ comes from the fuse block. In the 99-02, power and ground is fed directly to the o2 sensor heaters. To make the changes needed to 2003+ blue/green harness, to work with a blue/red computer is this:"
#440
Ls woo hoo
Again I would love to help
