Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Discovery 2 LS Conversion
Old Jul 2, 2020 | 11:37 AM
  #791
yardpro's Avatar
Originally Posted by Jacob81
he no longer sells to individuals/private party. He only sells to shops now. Best to try contacting him and asking which shops he sells the kit to and where you can pay to have it done
Thanks for the heads up. That means this will be a no go for us..... Would have been nice if they would have responded to my inquiry's and let me know this .
Old Jul 2, 2020 | 02:52 PM
  #792
05TurboS2K's Avatar
Greg,
use brennen/Brandon or whatever at LT1swap.com. He is still actively programming and does it full time. He will not respond to emails because he states on the site he is still programming. Just send your ecu with all the info requested and he will perform the tuning and return to you. Turnaround has always been about a week for me.
Ah I see, ok, a little odd but I suppose that works.
What did you leave for instructions? I see the site lists a few vehicles and such but our situation is a little unique. Did you just give the document provided by ACE to him?
Thank ya!!!!
-Greg
Old Jul 2, 2020 | 06:52 PM
  #793
Disco2.0's Avatar
Exclamation How do i get one???
Has anyone been able to contact ACEngineer lately? Ive been trying to contact him about purchasing a kit, with no response. if anyone has a kit laying around, or would sell it, i am EXTREMELY interested!!!! I am 18, and about to head off to college in a month or so, and my '04 just decided to eat all of its own bearings etc... Considering Im already doing a lt230 regear from 1.22 to 1.667, on 35' tires, i figured i could use the power, and reliability of the LS. At this point i am desperate to get my Disco back on the road.
Old Jul 2, 2020 | 06:58 PM
  #794
Disco2.0's Avatar
we have tried contacting him, and have had no replies.
Old Jul 3, 2020 | 10:00 AM
  #795
05TurboS2K's Avatar
Question for those of you using the PSI harness:
Wanting to double check, I see TWO ignition power pinouts for our ECU's, One is pinout Blue #75, the other is #19. My psi harness appears to supply power through the 19 pink wire, HOWEVER our instruction manual states power should be tapped from #75 which in my PSIcustom harness is blank...... Is this going to be an issue? Do I need to make a jumper perhaps? I would think there's a fair chance that this ECU will be looking for power in 75 and I'm worried it shouldn't be given power in 19. PSI hasn't been terribly helpful in answering this..... I believe it's the only thing up in the air at the moment on my electronics. It might be fine as is but I don't want to fry anything.
-Greg
Old Jul 4, 2020 | 02:32 PM
  #796
CaptainAaron's Avatar
-Greg
My PSI harness had a single red wire that is supposed to be 12V in the run/start position. I just connected that.
Old Jul 5, 2020 | 08:05 AM
  #797
05TurboS2K's Avatar
So you had the same situation as me then? 75 was blank on blue and 19 was a pink wire?
I'll see if I have a 12v run/start in red as you state. Do you know the pin # it was on?
Thanks!
Old Jul 5, 2020 | 09:20 AM
  #798
Thanks!
I can’t remember where red wire went for sure, but I’m pretty sure it went to the ignition relay on the little fuse box attached to the PSI harness. That was what my PSI manual said to use for start/run 12V wire, so that’s what I used. With everything else hooked up, I can hear the relays click on and the ECU turns on when that wire is connected to 12V.
Old Jul 5, 2020 | 09:57 PM
  #799
05TurboS2K's Avatar
OK. I guess I'm just concerned because the ECU is looking for power on 75 from what ACE says and it's not gonna get it from this PSI harness...... and it is instead gonna get it elsewhere potentially. I don't wanna fry it etc.
Old Jul 7, 2020 | 11:29 AM
  #800
2002 beast's Avatar
Hey dose anyone know I took a pcm out of a running 2002 Tahoe do I need to program it before I start my rover for the first time I don't want to hurt anything
