Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Here We Go Again, My LSX Swap Thread
Old May 23, 2014 | 07:53 AM
  #131
Shade Tree's Avatar
Originally Posted by dr. mordo
If memory serves, the flashing m and s lights are usually a dying battery or a grounding problem.
I'm betting you have a floating ground that you missed when you installed the engine.
Possibly, but I completely removed the TCU from under the driver seat, and the lights still flash. I can't figure how the IDM is even getting a signal to light them up. I studied the Rave diagrams and those lead me to believe that the signal comes from the TCU, but apparently not so.
Old May 23, 2014 | 07:54 AM
  #132
dusty1's Avatar
I like the sound of that...."serious testing"
Old May 23, 2014 | 08:38 AM
  #133
drowssap's Avatar
could it be that you dont have the proper voltage, most american car run 12.6-12.9vt alternator output; LR need over 13vt output or the ecm is it as low voltage?
Old May 23, 2014 | 09:21 AM
  #134
Shade Tree's Avatar
Good idea! I'll check the Ultra Gauge and see what the numbers are. I know it varies a little depending on when the alternator is charging. This might be a good reason to buy some Dakota Digital gauges to slip in that wonderful plastic dash. I think this one will fit.
Old May 24, 2014 | 08:58 AM
  #135
swank1975's Avatar
Amazing work. Keep it up. More pics and videos please..
Old May 24, 2014 | 09:12 AM
  #136
socal1200r's Avatar
Wonder if an old-school carburetted 289 or 283 would work in a Disco? You'd avoid all the electrical connection nightmares, and could install mechanical gauges for oil, water temp, volt, tach, etc?
Old May 26, 2014 | 06:20 PM
  #137
Shade Tree's Avatar
The actual feat of making your swap engine run is really easy. The challenges come in making all the accessories work properly.
A short list would be:
Transmission
Transfer Case
Drive Shafts (2)
Motor Mounts
Transmission mounts and crossmember
AC
Exhaust
Radiator
Cooler Lines
Power Steering
Shifter
Cruise Control
Fans, Mech and Electric
And after all that, the hood still has to close....
Whatever engine you choose this is no easy swap, but I have proved that it can be done. Deep pockets are not required, however an extensive knowledge of mechanics and some mad skills are required.
70 Miles on the replacement 4L65E (170 miles total), I plan to drive it to work this week, that will be good for 250 miles.
No joy on the AC yet, I had a failure on one of my home made hose blocks. I need more time to get that right.
Old May 26, 2014 | 07:31 PM
  #138
socal1200r's Avatar
In any event, you're to be commended for starting this project and seeing it thru to completion. I don't have such skills, tools, or patience, and if my engine went out, I'd either replace it with another one, or salvage the truck. I just couldn't deal with your long list of potential problems in swapping a different engine!
Old May 26, 2014 | 07:40 PM
  #139
mbruneaux's Avatar
The speedo only goes up to 160! With that powerplant you should be running the Baja! Great work, videos of it running and driving would be awesome.
Old May 26, 2014 | 11:40 PM
  #140
Dane!'s Avatar
Now that you've replaced the engine for a better one, you don't have to worry about all the Land Rover engine quirks, but you can still look forward to the other quirks the Land Rover comes along with. Cool thread.
