Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
jaguar motor in range rover 3.0 v6 aj126
Old Mar 13, 2024 | 09:00 PM
rangemb3's Avatar
5th Gear
Default jaguar motor in range rover 3.0 v6 aj126
hello i am purchasing a jaguar xf 3.0 aj126 motor can anyone tell me what i need to swap over to install in my range rover
Old Mar 21, 2024 | 05:45 PM
josephewers's Avatar
From what I can tell the long blocks are the same. So as long as you are pulling a motor out of your range rover that you can rob all the parts off of then you will be good. You will need all the seals and fluids associated obviously. You will need to swap over oil pan, exhaust, mounts and accessory brackets.
rangemb3
Range Rover L405 (Fourth Gen)
Apr 25, 2024 01:17 PM
cornbreadj
Apr 5, 2015 07:10 AM
rbuisa
Aug 28, 2008 01:05 AM
wease206
Apr 26, 2007 08:00 PM
roverfan
Aug 15, 2005 12:51 PM
