Engine Swaps This is the place to discuss any and all motor swaps for your Land Rover.
Stock MAF restriction with ACE LS swap
Old Mar 26, 2023 | 01:28 PM
CaptainAaron's Avatar
Originally Posted by Boostle
Aaron,
Do you have the setup up and running?
How much better is it? Worth the investment?
I don't have it in my D2 yet. Taking my time on the install and making some nice brackets to mount it, etc. But I did help two others with the electronics, so I know the electronic setup works. I drove one with the base map at 5% shift firmness (slightly more firm than stock) and it is more lively and the shifts are more positive. Instead of shifting regularly under mid acceleration at 2500 or so normally, it was more like 2800-3200. It holds gears a little longer. It changes how the Disco drives a bit, but overall I would say it is fairly sizable improvement, depending on what you want. Stock disco with stock LS, probably not really worth it so much. Heavily modded disco with modded LS, then probably useful to get the most out of the engine, and compensate for tires, etc.
The software is pretty easy to use. It works out of the box with some basic settings, but if you want to get really into it, you can. Sort of like HPTuners, but for the transmission.
I feel like that one on eBay is somewhat pricey, but it also has the display. If you want it, I'd see maybe if the owner would take less.
Thealooox
Jun 21, 2022 12:02 PM
boxsterrs60
May 19, 2019 12:39 PM
potxoli
Sep 5, 2013 09:18 PM
Roverpatsfan
Sep 16, 2009 08:16 PM
ezikial4
Jun 28, 2009 08:26 PM
