Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
Lr3 sunroof would not close
Old Jan 14, 2014 | 08:09 PM
619LR3's Avatar
Default Lr3 sunroof would not close
Hello, I've tried everything even the 20 sec reset calibration and nothing works.
I put a rubber strip along the side of the sunroof, when i finished i was closing it and it close but not all the way. the glass part is open half inch from the roof.
what should i do? is this going to be expensive? it's a 06 Lr3 SE.
Last edited by 619LR3; Jan 14, 2014 at 09:18 PM. Reason: where is the delete button, all is fixed
Old Apr 27, 2014 | 02:44 AM
Mr fix it's Avatar
5th Gear
Hi their try a battery hard reset, disconnect the positive cable and touch it to body of the vehicle. Then reconnect and switch ignition on hold the close button down on sunroof may take a while but should eventually close and recalibrate.
Hope this helps
j33p3r
Oct 7, 2016 05:19 PM
dominiquetx
Mar 9, 2012 11:53 PM
OhioDisco
Mar 6, 2010 11:19 PM
roving patrol
May 20, 2008 01:53 PM
tads
Aug 20, 2007 03:41 PM
