Freelander Talk about the Land Rover Freelander within.
'03 Freelander, went to change my spark plugs and can only find 3 !?
Old Aug 2, 2007 | 09:29 PM
rover's Avatar
8th Gear
Default '03 Freelander, went to change my spark plugs and can only find 3 !?
I mistaked the fuel injectors at first for the other 3 and spued gasoline allover...now the injectors seem to have play left to right after I put them all back, is that normal?
Where are the other 3 spark plugs?
Old Aug 2, 2007 | 11:46 PM
llesra's Avatar
Default RE: '03 Freelander, went to change my spark plugs and can only find 3 !?
the engine is a v6 so the plugs would be in the same place on the opposite side
Old Jan 8, 2009 | 06:55 PM
kyndrad77's Avatar
Does anyone know how to get to the back three spark plugs?Those are on coils. Do I have to take off the intake manifold to get to them?
Old Jan 9, 2009 | 03:20 PM
kyndrad77's Avatar
Answering my own question, just in case anyone else is wondering too...
Just got it done. Did not have to remove manifold. Did need a mirror to see the holes. Used 6 inch ratchet extension to get into the holes to remove and replace the plugs, and there was plenty of room for it. Remove the clips and plugs from the coils. Each has two screws that must be removed to remove the coil which are simple to remove and replace. Pull the coil out, pull plug, replace and put it back together. I did all 6 this morning in 45 minutes.
Old Feb 13, 2011 | 10:02 AM
ismael57's Avatar
Default backsparkplugs
What kind of mirror was used
Old Feb 16, 2011 | 07:48 PM
bentonrover's Avatar
The small kind they use in prison. Just kidding its good to know that it was pretty easy to do. Thanks for the post
Old Feb 22, 2011 | 04:07 PM
safira218's Avatar
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
agapelandrover
Nov 8, 2010 11:28 AM
Spencerfitch
Jun 7, 2010 09:47 PM
Spencerfitch
May 31, 2010 03:51 AM
philhan
Feb 29, 2008 06:24 PM
