Freelander Talk about the Land Rover Freelander within.
2002 freelander
Old Jul 5, 2010 | 07:18 PM
v6rover00's Avatar
Default 2002 freelander
had a question bout my 02 freelander, iv had problems recently with the engine running very rough while in drive, seems like it doesnt shift right and wen i drive it it on will go no more than 35-45mph, if i give it more gas it starts to shake and no power up hills, check engine was on and read misfire on cylinder 3, i replaced coil ignition packs and still shakes, problem is it only shakes wen in drive, i can manually shift and it is fine. any help would be appreciated thank you or if anyone has had same poblem
Old Jul 6, 2010 | 06:14 AM
Rovin4life's Avatar
maybe an injector but you need to start performing tests like fuel pressure and make sure everything is correctly installed. Make sure their are no air leaks.
Old Nov 15, 2010 | 04:35 PM
Hyjaxx's Avatar
Was this ever resolved? I have the same issue.
ANAN
May 6, 2007 01:31 PM
rlg905
Freelander
Oct 28, 2006 05:14 PM
sback1
Dec 9, 2005 12:40 PM
Neil
Aug 15, 2005 04:39 PM
ANAN
Jul 1, 2005 06:11 PM
