Freelander Talk about the Land Rover Freelander within.
2002 Freelander Noise
Old Jul 12, 2006 | 01:14 PM
Angelface's Avatar
Default 2002 Freelander Noise
Hello All,
As with most that join these things I'm having a problem. My wife has a 2002 Freelander, I think it's a SE. It has 60,000 miles. The check engine light is on, after having it checked they said the code said a major fuel leak. The thing is there is not a fuel leak, at least we have not seen any kind of a leak. Along with the light being on, there is a ticking noise coming from the top end of the motor. It sounds like a valve ticking or a small exhaust leak. All this happened after the switch in the shifter went bad and was replaced. The switch I'm talking about is the one that allows you to go from full auto to sport mode to manual auto. The noise started very small right after the shifter was replaced, and has gotten bigger. Any ideas?
Old Aug 12, 2006 | 06:22 PM
rinmud's Avatar
Default RE: 2002 Freelander Noise
the ticking noise is probably a bad upper intake manifold as far as fuel leak no no such p code it is probably the evaporative emmisions has a major leak usually the gas cap scott
P.S. If you need parts give me a shout ive been out of the country a while but im back
kskinner
Freelander
Oct 1, 2011 01:50 AM
ANAN
May 6, 2007 01:31 PM
sback1
Dec 9, 2005 12:40 PM
Neil
Aug 15, 2005 04:39 PM
ANAN
Jul 1, 2005 06:11 PM
