Freelander Talk about the Land Rover Freelander within.
72K miles service question
Old Oct 2, 2007 | 01:08 PM
kchao2000's Avatar
Default 72K miles service question
All,
What are things need to be done for 72K miles service? Oil change, replace oil filter, check brakes, tires... they are all basic, what else needs to be done? Should I replace timing belt (I heard there are two timing belts, is it true)?
Mine is 2002 Freelander S.
Thanks for your input.
Old Feb 19, 2008 | 01:54 PM
Blippie's Avatar
Default RE: 72K miles service question
Cheers
Blippie
Old Feb 19, 2008 | 09:24 PM
raid13's Avatar
there are three timing belts, one primary and two 2ndary.
suggest changing belts due to the fact the kv6 engine is an
interferance motor (if the belt brakes major engine damage will happen)
make sure that if you have someone change the belts that thay have the special tools
required to do this (there are alot required to do this job)
if you are in LA let me know i have done 4 kv6 timing belt jobs
Petie G4
15
Dec 2, 2014 09:35 AM
Dan_da_LR3_H2_man
Mar 5, 2014 12:24 PM
Waltmink1
36
Jan 19, 2011 06:45 AM
gtf8326
Jan 31, 2007 02:00 PM
phia@binoco.com
Dec 10, 2006 11:23 PM
