All,
What are things need to be done for 72K miles service? Oil change, replace oil filter, check brakes, tires... they are all basic, what else needs to be done? Should I replace timing belt (I heard there are two timing belts, is it true)?
Mine is 2002 Freelander S.
Thanks for your input.
there are three timing belts, one primary and two 2ndary.
suggest changing belts due to the fact the kv6 engine is an
interferance motor (if the belt brakes major engine damage will happen)
make sure that if you have someone change the belts that thay have the special tools
required to do this (there are alot required to do this job)
if you are in LA let me know i have done 4 kv6 timing belt jobs
