Freelander Talk about the Land Rover Freelander within.
Air Con Problem
Old May 29, 2010 | 11:57 AM
disco933's Avatar
4th Gear
Exclamation Air Con Problem
Hi can ayone help?
I have a 54 plate Td4 with A/C problems. I took it to a garage for a re-gas which they did £60, then told me my A/C did not work as the fuse had been removed. My mistake should have held their hands and got them to check if it needed a re-gas first which might have highlighted there was no fuse.
Anyway I have had an auto tech look at it and he says compressor, an air con specialist says sensor valve, I say can anyone help with an electrical wiring diagrame for the air con please. I have checked Haynes, the web and a Land Rover garage, no joy, it appears to be as rare as rocking horse s**t. I have a fairly good knowledge of electrics, and wonder why the fuse had been removed, so I would like to eliminate them first before spending hundreds on new parts.
Old May 29, 2010 | 01:33 PM
Rovin4life's Avatar
if they got a full charge out of it then perhaps its the pressure sensor but if they got say a half a charge then its the h valve on the firewall.
RANGER46
Nov 29, 2008 02:09 PM
snowdude
Sep 3, 2008 03:52 PM
specky
Mar 23, 2008 06:51 PM
skewett
Jun 3, 2007 08:15 AM
littlemissdisco
Feb 21, 2007 06:32 PM
