Another Coolant Question
I keep hearing about coolant problems so I want to check my level. Where is it???? I can't find the coolant under the hood. I admit, I didn't try more than 3 minutes--but anyone can give me a quick location?
Also, what are signs that you have a coolant leak? My temp gage is always at the 50% level which I believe is normal.
What causes these coolant leaks?
And for a preemptive strike--yes I know about the Freelander Cooling kit and why it's needed. Can anyone testify that this is the answer to our prayers?
Ok... I admit, it was a dumb question. My last car had blue coolant. I looked harder today and saw this car has a different color coolant used--reddish of sorts.
This is the situation: I have had the car (2.5L) 9 months, 3,000 miles. Coolant still on the Max level. Not totally clear; slightly cloudy. But definitely not that bad.
Any thoughts? What should I be looking for? Are there any warnings signs as far as the coolant or even oil colors go?
It might be good to know: 83k miles on this vehicle.
