Freelander Talk about the Land Rover Freelander within.
Another Coolant Question
Old Jul 10, 2009 | 12:05 AM
TheUninformedOwner's Avatar
Default Another Coolant Question
I keep hearing about coolant problems so I want to check my level. Where is it???? I can't find the coolant under the hood. I admit, I didn't try more than 3 minutes--but anyone can give me a quick location?
Also, what are signs that you have a coolant leak? My temp gage is always at the 50% level which I believe is normal.
What causes these coolant leaks?
And for a preemptive strike--yes I know about the Freelander Cooling kit and why it's needed. Can anyone testify that this is the answer to our prayers?
Old Jul 13, 2009 | 08:31 PM
Ok... I admit, it was a dumb question. My last car had blue coolant. I looked harder today and saw this car has a different color coolant used--reddish of sorts.
This is the situation: I have had the car (2.5L) 9 months, 3,000 miles. Coolant still on the Max level. Not totally clear; slightly cloudy. But definitely not that bad.
Any thoughts? What should I be looking for? Are there any warnings signs as far as the coolant or even oil colors go?
It might be good to know: 83k miles on this vehicle.
Old Jul 16, 2009 | 11:53 AM
squid's Avatar
4wd High
As you face the front of the truck, the resevoir is on the left toward the back of the engine compartment. It is usually translucent white with a black cap.
clint70
Dec 8, 2014 04:12 PM
trp34
Apr 24, 2012 09:18 PM
G Reeves
Feb 21, 2012 02:39 PM
01d2Jeff
Oct 19, 2011 05:38 PM
rtonder
Freelander
Nov 13, 2010 08:08 PM
