Freelander Talk about the Land Rover Freelander within.
Automatic transmision problems freelander 2
Old Dec 5, 2022 | 07:52 AM
Vangjo's Avatar
3rd Gear
Post Automatic transmision problems freelander 2
Hello!, i have a freelander 2 STD4 year 2007 automatic transmission. I have problems with the transmission because after i use the car for a while the car start to harsh shift the gears when it goes from the fist to the second and also when i change from D to R or N the change is very harsh. This doesnt happens whe the car is cold but only after i use it for a while in traffic. I changed the oil and made the software update f the gearbox but still the same result. Any Idea?
Old Dec 15, 2022 | 08:36 AM
Geordie Paul.'s Avatar
8th Gear
Default £1,800 rebuild.
Sorry but if you have done a full ATF change, you could have made things worse? Best to have someone with a fault reader to see if there any codes listed. I had Auto box problems with my last car and it cost £1,800 rebuild. It cost £35 for a full testing and you get a print out of the performance. I know that this is not much help with your problems, But sadly the longer you leave it the worse thing will get "Sorry".
Vangjo
LR2
Dec 6, 2022 05:10 PM
Vangjo
LR2
Dec 5, 2022 10:00 AM
david2000
Freelander
Dec 12, 2021 05:30 AM
TechDiver
Freelander
Sep 14, 2018 02:32 PM
Peter Mason
Jun 26, 2016 01:29 AM
