Freelander Talk about the Land Rover Freelander within.
coolant loss
Old Oct 13, 2010 | 08:58 AM
jonmyke's Avatar
3rd Gear
Default coolant loss
Had system pressure checked and ok. Loose about a quart every 200 miles. Radiator fan runs after turnoff and cools then I add coolant and ok. cannot smell or see any fluid
Old Oct 14, 2010 | 05:00 PM
TurkeyVegas's Avatar
look for a new engine,,,,it's going to get worse
Old Nov 2, 2010 | 04:57 AM
jonmyke's Avatar
3rd Gear
Mechanic added Bar Head gasket sealant and leak stopped.
Old Nov 2, 2010 | 10:25 AM
ac1dream's Avatar
I have the same situation, I am loosing all of the coolant in my reserve just about every 4 days. I am adding coolant every day. I have already had several hoses replaced and still same problem. Even with a pressure test, 2 seperate mechanics cant find the cause. Where else should I have them look. Thank you
Old Dec 6, 2010 | 09:05 PM
mirekl's Avatar
4th Gear
Hello
I have had the same problem
At the end it was loose cylinder liners and distorted cylinder head cover
Engine block, liners and cylinder cover got skimed and all is back to normal
Ask your mechanic to use exhaust gas leak detector fluid in cooling water
That's how I found it
Don't wait to long and you may save your engine
Good luck
Best regards
Mirekl
Old Dec 7, 2010 | 09:28 AM
ac1dream's Avatar
Originally Posted by mirekl
Hello
Good luck
Best regards
Mirekl
Still leaking coolant. Check engine light came on. No one can find the problem. I will try this. THANK YOU!
Old Dec 11, 2010 | 12:12 PM
mirekl's Avatar
4th Gear
You are welcome and good luck
You will need it
Best regards
mirekl
Old Dec 24, 2010 | 09:08 AM
sideburns's Avatar
Needs a motor due to cylinder sleeve seepage, (internal coolant leak).
akbarkhan
Mar 7, 2009 12:24 AM
jasmine
Jan 8, 2009 02:17 PM
riden686
May 5, 2008 02:29 PM
ontheroadagain
Mar 27, 2008 08:10 PM
focusontheworld
Dec 1, 2007 11:30 PM
