Freelander Talk about the Land Rover Freelander within.
Engine Swapped, now can't start!!
Old Jun 12, 2008 | 07:00 PM
casanova00's Avatar
Default Engine Swapped, now can't start!!
Brother-in-law bought an 2002 Freelander that the motor did not work. They swapped a new motor on there and know the trcuk does not want to start. Do you guys have any clue in which would goes this?
Old Jun 12, 2008 | 08:57 PM
roverguy7's Avatar
Default RE: Engine Swapped, now can't start!!
below the battery bos is the main engine ground, big black wire, it bolts onto the engine, its the same thread as the bolts for the batt box, only shorter, if youre not paying attention when you put it back together you can get it wrong and it wont be tight and cause a no start... by the way, is this a no crank or a no start?... but ive seen people get that bolt wrong a few times
TRIARII
Jan 17, 2014 07:32 PM
Grlica
Dec 11, 2013 11:49 AM
Bryan H
Feb 2, 2011 02:38 PM
sloppyjoe
Feb 16, 2009 01:03 PM
Willie 00D2
Sights N Sounds
Sep 3, 2008 04:09 PM
