Freelander Talk about the Land Rover Freelander within.
Freelander 1 2002 1.8 petrol engine
Old Oct 10, 2020 | 01:51 AM
fiinn's Avatar
Default Freelander 1 2002 1.8 petrol engine
While on the road with my Freelander the other day, the oil "low pressure" lamp started to blink. Stopped engine immediately and opened bonnet. Big oil leak from engine down at bottom right side (engine front where crank shaft pulley for v-belts is located). Anybody with similar experience who could enlighten me on what might have gone wrong? Much appreciate you assistance.
I opened up the engine front where crank shaft protrude through lube oil pump and found that the oil pump simmering had slid out resulting in the lube oil leakage described above earlier. Does anybody know or have an idea as to what the reason for this might be?
Last edited by fiinn; Oct 27, 2020 at 03:20 PM. Reason: Found reason for lube oil leakage.
Andrew Silver
Aug 28, 2016 06:57 AM
outback96
Freelander
Mar 9, 2011 07:12 PM
03se3
Engine & Internal
Oct 26, 2009 05:28 PM
slainiae
Freelander
Oct 5, 2007 10:22 AM
