Freelander Talk about the Land Rover Freelander within.
Freelander won't start!
Old Jun 23, 2008 | 01:26 PM
gmosley2008's Avatar
3rd Gear
Default Freelander won't start!
Need help! I have a 2002 Freelander with 47,000 miles. Have had it for two years and until now it has been ok. Lately, you can get in it and it will not start. Nothing happens, no click, no trying to turn over, nothing. Then after a few minutes it will start. Friday, as my wife applied the brakes while turning into a parking lot, it went dead. She called me to come get her. After several attempts at starting it with nothing happening, it all of a sudden started. I drove it to the house and killed the engine. I then restarted it. I killed it and restarted a scecond time. I did this for about four times in a row, all successful starts. I then mashed the brake. In fact, I stomped it. Then it would not start. No dashboard lights would come on. The headlights, radio, power windows all worked but it would not turn over, no click, nothing. That was saturday afternoon. All weekend I would try it and nothing would happen. Today (Monday), my wife tried it at lunch and it cranked. She then killed it and it would not crank again. I am at work at the moment and cannot see it. I know this maybe sounds like a battery, but shouldn't the dashboard lights have come on? And why does everything else work? Any thoughts? I would appreciate any you may have.
Old Jun 23, 2008 | 09:01 PM
ilsater1's Avatar
8th Gear
Default RE: Freelander won't start!
I had something similar happen but it was just a dead battery and everything went on for that except wen i tried to start it it just went click and nothing. Maybe its and ignition problem thats what i thought my dead battery was. Try new battery thats a cheap way to start troubleshooting.
Old Aug 6, 2008 | 11:07 AM
khal_dk's Avatar
Default frelander not starting
hi I change engine in my freelander diesel 2.0 . got everything fixed by the mechanic.
but the engine doen't start. A test was done. A wetted cloth with gasoline was put infront of the air inlet and then tried to start the engine. The result was that the engine started and run. The engine stop when removal of the gasoline wetted cloth. But the enigine dows not want to start on diesel. What can be the problem? Need desperate help from any one that has knowledge on this subject.
Old Aug 9, 2008 | 03:51 PM
LRSUX's Avatar
Default RE: frelander not starting
LAW OFFICES OF HOWARD A. GUTMAN
230 Route 206, Suite 307
Flanders, New Jersey 07836
Phone (973) 598-1980 Fax (973) 598-1982
Contact this attorney. There is at least 200 of us that have had, MULTIPLE problems with the F#@&landers. LRNA knows that they made a piece of crap car. Contact the NHTSA & let themknow how many problems you have had with this car & how UNSAFE it is. Thanks.
Old Aug 9, 2008 | 10:12 PM
raid13's Avatar
"LRSUX" commercial posts are NOT allowed!
do you have anything else to say other that the same thing every time
someone posts a question about a freelander on this forum?
nic1641
Sep 6, 2011 11:13 PM
ROVINGDAVE
Freelander
Aug 31, 2010 09:58 AM
Landie
Oct 18, 2008 05:40 PM
gmosley2008
Jun 25, 2008 07:00 PM
dcarsmith
Mar 8, 2007 10:16 PM
