front windscreen washer
has anyone had problems with the front windscreen washer? when i activate the switch, there is no noise. The rear one is working fine and you can hear the pump quite clearly.
the part costs $80 at a local shop and will take a week to arrive. wonder if this is a common problem and if i should dismantle to check connections before buying the replacement pump.
suggestions?
thanks!
02 freelander S
suggestions?
thanks!
02 freelander S
JavaDiscoII
05-16-2010 03:34 PM
