Freelander Talk about the Land Rover Freelander within.
front windscreen washer
Old Nov 27, 2008 | 03:14 PM
egb's Avatar
egb
3rd Gear
Default front windscreen washer
has anyone had problems with the front windscreen washer? when i activate the switch, there is no noise. The rear one is working fine and you can hear the pump quite clearly.
the part costs $80 at a local shop and will take a week to arrive. wonder if this is a common problem and if i should dismantle to check connections before buying the replacement pump.
suggestions?
thanks!
02 freelander S
blue marbles
Freelander
Jan 16, 2017 01:14 PM
james.martin1
Oct 10, 2013 07:56 PM
yallie
LR4
Aug 7, 2011 08:23 PM
JavaDiscoII
May 16, 2010 03:34 PM
krazzz
Jan 15, 2010 07:17 AM
