Hello & IAT sensor
Hello All. My name is jon and I live in Liverpool Merseyside. A Land Rover nut in training. Member,treasurer and website co[ordinator for a Land Rover club.
I am after information on where to locate the IAT sensor on a Freelander 1.8 petrol 52 plate!! Can anyone help ??
Many thanks. rgd's jon.
[ol][*]Fuel pressure regulator[*]Manifold Absolute Pressure (MAP) sensor[*]Fuel rail[*]Injector (4 off)[*]Idle Air Control Valve (IACV)[*]Throttle housing[*]Fuel shut-off switch[*]Engine compartment fusebox[*]Air Conditioning (A/C) relay[*]Main relay[*]Fuel pump relay[*]EVAP purge valve[*]Engine Control Module (ECM)[*]Throttle Position (TP) sensor[*]Crankshaft Position (CKP) sensor[*]Engine Coolant Temperature (ECT) sensor[*]Intake Air Temperature (IAT) sensor[*]Camshaft Position (CMP) sensor[*]Upstream oxygen sensor (HO2S)[*]Engine oil temperature sensor[*]Engine oil pressure switch[*]Ignition coils[*]Malfunction Indicator Lamp (MIL)[*]Starter catalyst[*]Main catalyst[*]Downstream oxygen sensor (HO2S) [/ol]
[IMG]local://upfiles/6306/657A545C335F466CBBFBD19E54DE1490.jpg[/IMG]
i have worked on a lot of freelander but never one with an four cylinder engine.
there are no four cylinders state side here only the kv6 six cylinder.
sorry thats all i got.
Pursan
Aug 9, 2011 08:14 PM
Speed racer
Oct 29, 2008 12:45 AM
