Freelander Talk about the Land Rover Freelander within.
Hello & IAT sensor
Old Sep 21, 2008 | 03:23 PM
tugumafu's Avatar
3rd Gear
Default Hello & IAT sensor
Hello All. My name is jon and I live in Liverpool Merseyside. A Land Rover nut in training. Member,treasurer and website co[ordinator for a Land Rover club.
I am after information on where to locate the IAT sensor on a Freelander 1.8 petrol 52 plate!! Can anyone help ??
Many thanks. rgd's jon.
Old Sep 23, 2008 | 09:20 AM
raid13's Avatar
Default RE: Hello & IAT sensor
[ol][*]Fuel pressure regulator[*]Manifold Absolute Pressure (MAP) sensor[*]Fuel rail[*]Injector (4 off)[*]Idle Air Control Valve (IACV)[*]Throttle housing[*]Fuel shut-off switch[*]Engine compartment fusebox[*]Air Conditioning (A/C) relay[*]Main relay[*]Fuel pump relay[*]EVAP purge valve[*]Engine Control Module (ECM)[*]Throttle Position (TP) sensor[*]Crankshaft Position (CKP) sensor[*]Engine Coolant Temperature (ECT) sensor[*]Intake Air Temperature (IAT) sensor[*]Camshaft Position (CMP) sensor[*]Upstream oxygen sensor (HO2S)[*]Engine oil temperature sensor[*]Engine oil pressure switch[*]Ignition coils[*]Malfunction Indicator Lamp (MIL)[*]Starter catalyst[*]Main catalyst[*]Downstream oxygen sensor (HO2S) [/ol]
[IMG]local://upfiles/6306/657A545C335F466CBBFBD19E54DE1490.jpg[/IMG]
Old Sep 23, 2008 | 09:38 AM
tugumafu's Avatar
3rd Gear
MANY THANKS FOR THAT RAID 13.I HAVE LOOKED ABOUT. CAN YOU GIVE ME A DETAILED BRIEF AS I AM NOT THAT MECHANICALLY MINDED. THANKS AGAIN IN ADVANCE REGARDS JON.
Old Sep 23, 2008 | 12:19 PM
raid13's Avatar
i have worked on a lot of freelander but never one with an four cylinder engine.
there are no four cylinders state side here only the kv6 six cylinder.
sorry thats all i got.
Old Sep 23, 2008 | 12:28 PM
tugumafu's Avatar
3rd Gear
Many Thanks for your help so far. Best wishes and kind regards, jon.
Pursan
Aug 9, 2011 08:14 PM
Speed racer
Oct 29, 2008 12:45 AM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
colby80210
Jan 19, 2007 03:52 PM
kng_kupa
Engine & Internal
Jan 4, 2007 06:13 PM
