Freelander Talk about the Land Rover Freelander within.
Hill descent light and Traction control light are ib
Old 09-23-2005, 10:41 PM
newfrl's Avatar
Default Hill descent light and Traction control light are ib
I bought a 2002 Freelander just today. Loved driving it home. When I got it home the Hill descent light and traction control light came on. Help! Does anyone know why? AW
Old 09-24-2005, 12:29 AM
modyfyit's Avatar
Default RE: Hill descent light and Traction control light are ib
did you just have a service done to it? or the battery replace/disconnected or even the wheels or wheel taken off... if none of the above go start the car and see if they come back on... i just did a service on one and on the test drive they came up but went to lunch came back started car drove and they were gone hooked up t4 and nothing so hopefully it is just checking itself if it is still on let us know
Old 09-24-2005, 11:27 PM
newfrl's Avatar
My husband was able to put the car in reverse a couple of times which seemed to do something to maybe set the brakes! I am not car-literate so bear with me! Anyway, the lights have not come back on so all is good . What an amazing Freelander! Great car! Thanks for the response. AW
Old 09-30-2005, 07:13 PM
2003FreelanderSE's Avatar
Just had this fixed on mine (I hope). The dealer could not find any fault codes, but indicated that sometimes the stop light switch causes this issue. THe service manager flipped the part in so quickly that I didn't even get a copy of the work order, so I don't have a part number.
Old 10-01-2005, 08:49 AM
rinmud's Avatar
Believe it or not it is the brake light switch, I install around 10 a week for this reason. $47.00 for the switch and takes around 5 minutes to install beneath drivers dash
rob bartleman (02-10-2024)
Old 03-14-2006, 04:33 PM
jtrieu's Avatar
The real reason is that it's a lemon!!
I have a Freelander 2002 and I've had nothing but problems with it. Landrover has actually discontinued the model. You can check on their website...it doesn't even list it as a model any more. I've had my rover in the shop 12 times and 11 of those times was for replacement of defective parts!! Not a good percentage.
They advertise that this vehicle is the most travelled vehicle on earth and yet I can't get it out of the driveway!!! They talk about adventerous, quality, and supermacy but I have not seen any of these qualities. Save your money and buy something else.
Kirill Khadar (08-27-2020)
Old 06-07-2010, 09:23 PM
anandsangwan's Avatar
Default Hill Descent Light and Traction Control Light
Hi could anyone please tell me where to find the brake light switch in Landrover freelander. From internet I could see that if the hill descent light is and traction control light is on then its something to do with Brake Light Switch. thanks
hichamaziz (03-06-2018)
Old 06-12-2010, 10:27 AM
Rovin4life's Avatar
yours should have had the recall done where all the switches have been replaced by the dealer. Take it to them. If the recall has been done and its not the switch they can get you an accurate diagnosis.
Old 06-16-2010, 10:07 PM
bentonrover's Avatar
Mine been pretty reliable except for the heater core.
Old 08-20-2010, 10:09 PM
georgery's Avatar
7th Gear
Default brake light switch
the problem is the brake light switch, have it replaced your local land rover dealership, this is a recall so they can not charge you for this fix, had mine done 2 years ago and not one problem since
Quick Reply: Hill descent light and Traction control light are ib
