How do you remove front part of console?
Picked up an 02 Freelander that needs the Head Gaskets... OK, I know...
Looked really clean, and had a little bit of an odor - no big deal, seen, cleaned up worse. Then when cleaning it, the smell got worse... Did my Green Machine thing and it smelled o.k. after doing it, but after it dried, the smell was back... SO, I decided to remove the seats (which I often do when cleaning the carpets... Then wham it hit me like a brick when I lifted the carpet a little...
Bottom line, is that whoever rode in the rear right needs to learn how to hold a beer when riding... I mopped up about 16 oz. of fermenting brew.
I have removed the rear console, and the two screws on the front console but did not see where it was obvious as to how it came out. It was late, and did not want to break anything.
SO:
- What is the trick to removing:
1. Shifter ****
2. Front part of console
I'm planning on getting the carpet out and cleaning the foam outside of the vehicle.
Thanks.
SO:
1. Shifter ****
Thanks.
1) the shifter, pull up like you dont care, best when in N (be careful not to hit your self in the face when it comes off)
2) front part of console, under the e-brake handle there is a cover hiding two screws.
3) your going to have to cut the rug under the hvac heater box unless you plane on removing the dashboard/hvac box.
4) when LRSUX leaves his spam type comment please send p/m to administrator so we call all get him kick off or band.
thanks and good luck
ORIGINAL: raid13
ORIGINAL: raid13
And I have the two screws on either side of the front console out. So, the front console moves a bunch, but is attached somehow around the dash - I just did not want to break any plastic last night investigating because nothing was obvious. I'm hoping I do not have to remove the radio.
What I'm looking for is how to remove the front part - the part over the shifter and that contains the wallet box, heater control area. Enough to get the carpet over the shifter.
Are there two screws under the heater control ***** that need to come off?
ORIGINAL: raid13
ORIGINAL: raid13
For anyone looking, I'll answer my question as I just figured out how to get the front part of the console out. Start with the rear (though I already had mine out):
- 4 screws on the top of the cubby
- 2 hidden screws under the cubby
- 2 screws under the plate under the e brake handle
Pull up on the e brake and remove the rear part
Front Part:
Pull up on shifter to remove handle 9 be a little careful, but firm (believe it or not I have seen a BMW shifter that was broken...)
Remove:
- 2 screws on either side of console (in the footwell area so to speak)
- pull three ***** off the heater area.
- 2 screws under two of the *****
- 4 screws around the heater control
- radio including the recctangular retainer by bending the tangs
- 2 screws hidden by the retainer - you might be able to get to these, but it looked like I had to remove it and did not want to break anything.
- remove a ton of connectors
- remove console
Well, now I see how much cutting it would take to get the carpet all the way out.
I think I'll try to soak the padding with clean water, squeeze it out and then repeat with a cleaner. put it up in the air to see if it will dry before going further. Getting the console all the way out helps give me more room under the carpet now.
Thanks for helping. I would have been a little hesitant to just yank the shifter...
Front Part:
Remove:
- remove console
Ended up cutting the carpet in three places to get it out from behind the air control stuff.
Sprayed it down a bunch, and it is hanging on sawhorses. I really hope the padding dries all the way.
While there has been write ups on the evaporator drains clogging and I'll check that, the liquid really smelled like brew. It even foamed up when I sprayed the padding. It smelled worse than my fraternity basement floor after our parties - and we could party.
wheelgarage
10-01-2011 03:12 PM
orion27
11-06-2008 08:16 AM
sna77
07-10-2007 06:02 PM
