Freelander Talk about the Land Rover Freelander within.
ignition coil code
Old 03-23-2017, 04:10 PM
meginsf's Avatar
5th Gear
Default ignition coil code
Hey guys Well I just bought my landy and the guy that i bought it from knew and about the p0303 sode that it has been putting out. He had his mechanic "fix it" 2 or 3 times. It has been consistent with that code until today when i took it to a guy that works only on land rovers.. he got a
P0303 Ignition Coil 3 misfire
P1383 Ignition feedback resister
the mechanic said that he changed the wiring as they were old and corroded when that didnt fix it he relaced the coil. The landy mechanic said that the original guy either used cheap parts OR replced the wrong coil as some of the mechanics that dont work on landy often dont know the cylinder line up. im at a loss what should i do next. Im pretty sure that my husband is going to try and return it BUT we are past our 5 day return policy. thanks in advance
mx468
12-11-2015 06:45 AM
trialrun
11-11-2014 08:41 AM
b_woodroaster
11-05-2010 08:54 AM
GoldDiscoII
01-31-2009 09:09 PM
GoldDiscoII
12-03-2006 12:06 PM
Quick Reply: ignition coil code
