Freelander Talk about the Land Rover Freelander within.
little difference on fuel pump Freelander Petrol.
Old Aug 29, 2012 | 01:21 PM
Jim Vargas's Avatar
4wd High
Default little difference on fuel pump Freelander Petrol.
I have a problem with my fuel pump and filter. In Mexico its hard and expensive to get parts from Land Rover, I found a remplacement for the fuel pump but have a little difference, the original part don't have any return conection, the remplacement part have one. I don't know if have a problem weld this return conection. I think that increment the pressure. Do you have any idea?
Old Aug 29, 2012 | 09:26 PM
Jim Vargas's Avatar
4wd High
Hi Saru.
It's a 2003 year. The engine model is a KV6. In fact the original fuel pump it's a VDO system. The remplacement part is a VDO module pressure. Both pump fuel are high pressure system. I have some photo but can't show here. Thanks for you recomendations.
Old Aug 29, 2012 | 11:19 PM
Jim Vargas's Avatar
4wd High
This is a photo from the compare to both fuel pump
Attached Thumbnails little difference on fuel pump Freelander Petrol.-img-20120827-00382.jpg
Old Sep 4, 2012 | 03:33 PM
Rovin4life's Avatar
They fuel pumps were actually under recall in the US. Might be the same for Mexico. If not take a trip over the border.
Old Sep 6, 2012 | 12:22 AM
Jim Vargas's Avatar
4wd High
Hi Rovin4life.
Do you know what is the problem with this fuel pump on US. My original fuel pump it's the same model.
Regars
Jim Vargas
Old Sep 6, 2012 | 08:50 AM
Rovin4life's Avatar
They were junk. We replaced every single one under warrantee.
Call the nearest dealer and talk with them. if it has a US vin number it will be under warrantee. just take it north of the border. If its Mexico you can call land rover and check with them.
roverbob
Sep 2, 2012 08:34 PM
TYoung
Freelander
Aug 17, 2010 04:19 AM
mikegoose
Freelander
Feb 5, 2010 05:52 PM
StefanA
Nov 8, 2009 03:23 PM
Desmo16
Jun 30, 2009 03:05 PM
