Freelander Talk about the Land Rover Freelander within.
loud pop in rear end when i put into drive
Old Nov 27, 2008 | 05:33 AM
freelanderjames's Avatar
8th Gear
Default loud pop in rear end when i put into drive
I start my o2 freelander. Shift into reverse. Sometimes is makes a loud pop sound. But when I go into drive its a loud thump/pop sound in the rear end.
And when it downshifts to get on the freeway is pops too. Sounds like I rip the rear end up. Its horrible.
Please share your knowledge .... pretty please.
Its not altered in anyway supensionwise.
Thank you ahead of time!
Old Dec 9, 2008 | 10:59 PM
tacomatech's Avatar
Default RE: loud pop in rear end when i put into drive
You have a torn rear differential front mount bushing.
Old Dec 11, 2008 | 11:17 AM
CCWheat's Avatar
I just had one replaced on my '02 SE; it was a very painless and inexpensive fix. Mine went out about 56,000 miles. Good luck, tacomatech nailedit.
Old Dec 11, 2008 | 11:44 PM
tacomatech's Avatar
It's a very common occurence, I typically see them starting to tear around 50k. The side mounts seem to hold up well though.
Old Dec 12, 2008 | 01:11 PM
8th Gear
Thanks for the info , the dealer said i have to replace the rear end , i about s**t myself . gotta love "honest" LR dealerships.
I just rolled 124k on the freelander. i drive about 5k a month. Is there any other preventative thing you could recommend? i have had this car since 12k miles and i have just done factory servicing only.
thanks guys.
Old Dec 17, 2008 | 01:44 AM
tacomatech's Avatar
Just stay up-to-date with the factory servicing and change the oil every 3k. Dont' take chances with these.
Old Dec 24, 2008 | 10:18 PM
2002 freebie se's Avatar
Hj, all. Does this problem also result in vibration? I'm feeling some, mostly on the left side, in front. I notice a thump from the rear when I hit the gas sometimes. Like there's play in the connection of the diff and driveshaft.
Thanks.
bamaboy473
Feb 15, 2013 01:40 PM
tsam19
Freelander
Jul 28, 2011 09:50 PM
Pwn777
Sep 16, 2009 06:28 PM
Rover Chris
Jan 26, 2009 09:15 AM
pelias
Aug 13, 2008 04:54 PM
