Freelander Talk about the Land Rover Freelander within.
The missing problem again.
Old Jul 9, 2023 | 11:36 AM
Xamon's Avatar
Default The missing problem again.
Okay I know this has been covered all over but having done everything I am stumped. So onward:
Code p0305, miss on number 5. reset codes for each step. Swapped coil with #3 no change. New plug no change. Checked for spark, no spark, if I plug that coil and plug to a different lead it gets spark. opened ecu box and checked continuity on each wire, black purple fine, brown pink fine, black goes to ground. So at the moment I am lost as to where to go next. Any help is appreciated. Thanks.
Old Jul 10, 2023 | 04:01 PM
BillF's Avatar
4wd High
How about the fuel injector?
Old Jul 11, 2023 | 09:33 AM
Xamon's Avatar
That would have been next to check if I had spark. Still might need checking. I have arranged for it to go to a mechanic Friday so they can use a better scan tool etc.
Jared9220
Feb 14, 2015 05:00 PM
pinkytoe69
Jul 2, 2013 10:48 AM
harvy17
Jul 30, 2010 09:53 PM
glmtd
Jan 8, 2010 11:51 PM
LRDKW
Mar 26, 2008 08:59 AM
