Freelander Talk about the Land Rover Freelander within.
Mystery Coolant Leak
Old Nov 23, 2008 | 04:41 PM
XR4Tim's Avatar
4wd High
Default Mystery Coolant Leak
I'm helping a friend do some minor repair work/maintenance on his 2002 Freelander.
The teardown started when the motor started leaking copious amounts of coolant from an unknown location. After getting it apart, it appears that the coolant is coming out of a sort of "chute" in the block, under the rear head, next to the timing belt tensioner. Does anyone know where this passageway leads or why coolant would be running out of it? My only guess is that it leads up to the head, and a head gasket leak is the culprit, but I can't find any suitable diagrams to help.
Any suggestions are appreciated.
The custom fabricated cam-holding tool will be available for purchase when this thing is back together [8D]
Old Nov 25, 2008 | 12:05 AM
tacomatech's Avatar
Default RE: Mystery Coolant Leak
Thermostat housing and bypass pipe. Located in the valley between the heads. They are common for leaking and when bad enough, can look like coolant is leaking out of the timing cover area.
Old Nov 25, 2008 | 06:10 PM
Lonewolf_ky's Avatar
I just had this problem. One of pipes, probably the short fat one, that attaches to the thermostat has cracked. You have to take the intake off to get to it. What a place for a thermostat.
Old Nov 25, 2008 | 09:51 PM
XR4Tim's Avatar
4wd High
Thanks for the replies. I'll check it out tonight. At this point, taking the intake off is no big deal. It'll be much better than a head gasket.
Old Nov 29, 2008 | 11:33 AM
XR4Tim's Avatar
4wd High
Anybody have any suggestions for removing the upper intake? I got the 4 bolts that hold it to the lower intake, and the two brackets that hold it to the rear valve cover, but it still doesn't want to come off. What am I missing?
Old Nov 30, 2008 | 09:52 PM
Mine was difficult to get off also. Just carefully pry around on it. The seals make it difficult to remove. I bought a thermostat kit that included a new intake gasket and new seals.
Old Dec 3, 2008 | 12:07 AM
XR4Tim's Avatar
4wd High
Yup, it was those seals making it really difficult to remove. The culprit turned out to be the thermostat housing. The bottom of it was broken, right where the o-ring is. Thanks for the help guys!
Old Dec 23, 2008 | 05:47 AM
rinmud's Avatar
you guys the cam is not going to spin enough to damage the valves. Ive done many belt changes on freelanders the ruler and the paint sticks make me sick, so stop posting them. Lock the crank (3/8 inch drill bit in the hole in the front) and look at the cam marks. scott
Old Dec 30, 2008 | 02:07 PM
riptide33's Avatar
4th Gear
I replaced the thermostat, the tube behind it and the long tube that runs from the thermostat towards the water pump without removing the manifold. It wasn't the easiest thing in the world but can be done without having to remove the manifold. Patience, extensions and swivel sockets came in handy. Wouldn't want to do it again.
ZMonet
Jun 24, 2016 04:00 PM
jobooth
Dec 9, 2013 01:41 PM
IDisco2
Aug 5, 2012 05:54 PM
mac25dm
Jan 21, 2008 08:21 AM
meyersd
Oct 9, 2006 09:21 PM
