Freelander Talk about the Land Rover Freelander within.
Is it the nutreal safety switch
Old 07-20-2018, 11:13 PM
Ultramag's Avatar
Default Is it the nutreal safety switch
Okay my wife was driving home when she lost power coming up the last hill to our farm and the 2002 freelander just died at the top of the hill and would not start again now the starter sounds like its not engaging all the way but the altinator belts are turning when its being cranked over but the motor is not turning over fully what could this be?? I had the starter out and bench tested it and its fine lots of snap to it! Could it be the nuetral safety switch??
Old 07-21-2018, 10:04 PM
XCELLER8's Avatar
not likely the ns switch....or nothing would happen when you turn the key......what shape is the battery in ?, have you had it tested ?, and make sure the alternator is actually charging the battery for starters....no pun intended
Old 07-21-2018, 11:36 PM
Ultramag's Avatar
Well i had the battery charger on the battery on 30amp cranking power and still got the same results the battery is in good shape
escott16
01-10-2019 06:09 AM
Fizzbiz
12-07-2018 06:17 AM
Buddyp
01-20-2018 03:46 AM
discobob
06-17-2015 10:26 AM
fmbchoppers
04-26-2014 04:13 PM
Quick Reply: Is it the nutreal safety switch
