Freelander Talk about the Land Rover Freelander within.
please someone help about hdc system failure error code P0718 and P0732
Old Mar 28, 2022 | 11:29 PM
jpbiaggi's Avatar
Default please someone help about hdc system failure error code P0718 and P0732
friends recently bought this freelander 2, a dream car for the comfort feature and common durability of parts. as it is chronic in them and no one answered here the possible solutions and I succeed in the repair, I open this topic because I am desperate in the situation. after a few days of use, it started to show the hdc fault system error and started to stay only in 3rd gear, as when I turn it off and on it goes normal and after 1 km, 50km, 100km I learned to use the manual mode before the error in which I can walk on roads even with error. apparent battery in good condition, green level of moura 75amp, I connected the battery negative to the valve cover, halogen lights, nothing connected, to oscillate the voltage, and the error continues. I saw cases abroad and nationally, with no effective cause, I used the homemade scanner and a professional got error P0718, and when I turned it off I started having error P0732 referring to 2nd gear, which reduces the rotation to gear and engine performance. I need help from people who know, or have already had similar cases so I can check the sensor, connection, part replacement, any help will be of great compassion. I'm counting on you whats +55 16 99743 3410
Dan_da_LR3_H2_man
Mar 2, 2025 01:18 PM
sh74
LR4
17
Dec 20, 2024 01:08 AM
HedgePig
Feb 13, 2020 02:19 PM
Gordon C Payne
Freelander
Jun 29, 2015 06:40 PM
